LarryBoy
7
Okay, I just changed my first tire, what a pain!
As I was changing it the little spacers that go between the swingarm and the hub came off and got some dirt in there. I cleaned them out, but do I need to put new/more grease on them?
There is some, but I am not sure if I should put on some more. If so, is basic white lithium grease or moly based caliper grease okay?
Thanks much!!
LarryBoy
7
The pieces that go on either side of the hub between the swingarm and the hub itself, they appear to be a spacer that does not turn with the hub. The axle goes through the middle of them...
I went ahead and slapped some moly based brake caliper grease on them and put everything back together for now. I guess if I shouldn't do that then I will need to clean everything out real well and put what I should on them?
Thanks much!!
