handlebar vs triple clamp attached
GWO
58
Who is using triple clamp attached bark busters?
I noticed Emig Racing is selling special triple clamps for attaching your bark busters and claiming that if you attach to normal style (front side pinch bolts) that you can't clamp down as tight.
Has anyone had a problem mounting to the triple clamp on their japanese bike?
GWO
'02 YZ 250
KTM/MAICO
108
GWO, Triple clamp mounting gives a very secure and easy location to mount the bark busters. Most riders shorten their bars to run tight woods, but it reduces the amount of surface area to mount the front clamps. A lot depends as to what size bars you are using. If you use regular bars with the same outside diameter over the entire distance of the bars then its easier to use any system. If you run pro tapers or other wide bars they have different diameters depending on the make and how short you cut your bars. The kits for the wide bars work okay, but you need to find the right front clamps for the make of bars you are using. Pro taper front mounts don't fit my shortened Magura bars on my KTM. I went with front clamps designed for the Magura bars from EE and they work great.
Scott Summers has been running the triple clamp method for years with great success. I modified an old super vintage Husky by bolting a hand made bracket that was about four inches long, using three holes. The two upper triple clamp bolts went thru the lower two holes of the bracket and the bark buster was bolted thru the upper hole and it worked great. Had to get longer clamp bolts but they came from a local hardware store.
The triple clamp mounted bark busters just give us an additional way to enjoy our sport.
94ruck
318
One of emigs buddies broke the bolt off of his triple clamp after hitting a tree. That is why he make the attachment seprate of the pinchbolt. The pinch bolt clamps around the fork and there is a seperate mounting point for the barkbuster for saftey reasons. Plus this raises the barkbuster up a little higher for better hand and control protection. He makes adjustable brackets for different width bars. Aks him about his trick handlebar insert trick. No more spinning barkbuster!!
