tomoad
23
MY 03 CR 250 WHILE IN THE POWER BAND IS HARD TO SHIFT OR GET INTO A HIGHER GEAR UNDER HARD ACCELRATION. SHOULD I GO TO AN AFTERMARKET CLUTCH OR HOW CAN I FIX THIS PROBLEM. TRIED ADJUSTING THE CLUTCH BUT DID NOT HELP, ANYONE ELSE HAD THIS PROBLEM, AND WHAT WILL CORRECT IT.
tony91
493
I had the same beef with mine for the first few rides. Seemed to go away with time. My only problem now is that I can't adjust the shifter as high as I like it. How many hours do you have on it ?
tomoad
23
10 HRS IM GUESSING, IT GETS OLD SHIFTING FOR ANOTHER GEAR AND IT WON'T GO IN TILL YOU LET OFF THE JUICE..
tony91
493
I hear ya. It sucks. I would give it a while before making any changes. Hopefully some of the other guys with 03 Cr250's will chime in.
