2-strokes-4-life
- Mar 1, 2005
- 231
- 0
first off let me say i did read the jetting links befor i attemped to jet.ok,as you all know i have been trying to get the 125 jetted right.im trying to eliminate a lean bog above idle.i have gone from a 37.5 pilot to a 55 and it still bogs,and with the stock pilot being a 45 this makes no sense to me.it had a leaner than stock needle in it so after trying that i ordered the stock needle which i think helped but it still bogs.bike has a fresh top end,clean filter and a new left crank seal.im also running 110 race fuel.oh yea about the seal,i took my fw cover off today and found liquid in there again!i couldnt believe it since i had put in the new seal per the manual.my father tells me that it could be some of the grease we used to install the seal getting hot and draining off alttle.is this possible?the reason i assume its a lean bog is because if i dont release or at least back off the throttle it will die and i will have to restart it.also once i restart it,it sounds alittle lean but as soon as i give it a blip of throttle it sounds fine.i guess the reason for this is because there is no fuel there and when it dies like that its because its starving itself out of fuel.please someone offer some feedback,im totally lost on what to do short of paying a shop to diagnose it,which they wont be able to ride the bike so they cant be of much help for jetting.although they'd take my 80 bucks in labor if i offered :think: also if anyone need's more details i will try my best to provide
