Not sure what to think. The kickstarter on our 99 wont return all the way back up after you kick it. It starts, mind you, but when the you shut off the motor the kickstarter will shake violently back and forth. Weird stuff.
Also, if I have the bike in gear with the clutch pulled in and spin the wheel, the kickstarter will ratchet back and forth once, and then it stops...
I did pull the cover off to take a look and it seemed like the return spring was working fine.
Any suggestions?
Much thanks!
JJ
Any suggestions?
Much thanks!
JJ
