andywright03
- Jan 9, 2007
- 5
- 0
Hi all new to the site so hello to every one
Right got 2 bikes a yamaha YZ250 1999Year
Honda CR250 around a 1998year
First of the honda cr250 bought it couple weeks ago just had new piston and gaskets, but took it out and it blew the head gasket with in half hour of takin it easy found that some head nuts were loose so any way new gasket and the same happened again but also noticed when it was running it is always pushing water out the over flow so stripped it right down and just carnt find anything wrong engine has been presure tested and has come back ok any ideas????
Right now the yamaha bit simpler i hope to fix when the fuel gets around half way in the tank it just bogs down totaly if i fill it up again its fine on and off , i have cleaned the tank out thinkin it would cure it with the amount of bits i got out of it . it sounds fuel related but just carnt think could it be the fuel mix ???
sorry for the long post just hope some one can help me Cheers in advance Andy
