- Jan 1, 2001
- 3,043
- 9
Terry,
So I got the TR6R, as you already know. The fun has just begun, I fear.
I thought I wouldn’t need much in the way of parts but it seems the list is not really a short list but rather a living list.
1st thing I noticed is the plugs were extra black with soot and they were B7s where the book says B8s. So I got some new B8s and a 190 main jet (had a 230 but I’m at 5000’).
Starts up nice and runs purdy good.
Now the oil leaks seem more than I was prepared for. So I got out my good glasses and my bright light and started studying the under the neath.
Hmmm, seems like a steady drip coming from the primary drainer plugger/chain adjuster. So I take off the primary cover and give it a gooder look.
Well the dang case has a bit of a crack or it seems like maybe the drain hole/adjuster doodad hole maybe has been drilled and retapped leaving a not so beefy place to keep the oil in if it cracks. But when I tighten the plug the crack doesn’t seem to open up any bigger. I used a couple cans of PJ contact cleaner to douche out the oil and then I filed the crack with a tiny file of the exact right Whitworth dimensions and then I got some AngloSaxon JB weld and some more PJ. Douched it again and filled the flaw with the perfect mix. Left a hunnert watt bulb aimed at it for a couple days and put it back together. There sure is an impressive number of places for these things to leak oil.
Went for a ride, checked for leaks, went for a ride, no leaks. Awesome! Let it sit in the garage for 5 days and not a drop. Awesommer!!! Went for another ride and it burnt up a set of points. Got some newn’s and some condensers and put ‘em in. Thought I’d better just check the valve clearances and the intakes were fine but the exhausts were tightern’ Pred wearin’ his wife's panties. Adjusted ‘em (valves not Pred's panties) and tried to fix the horn too ( I only throw that in because everything seems to be connected in some way to the center of the universe). Well couldn’t fix the horn but I put it all back together and it started right up and sounds great.
But the oil light slowly started brightening until it glows steady. Well that seems like an odd thing to happen all of a sudden. I took out the sending unit and made a Rube Golberg contraption to get 20 psi on it and I can make the light go on and off at will.
So, what do you think I goofed up to lose oil pressure? I started it with the sending unit out and oil comes out the hole real good.
Also, it sure is hard to remember that this thing is positive ground and shifts on the right!!! I mean it only matters when you forget.
Wes
Wes
