Faded
- Jan 7, 2003
- 842
- 0
EG just rebuilt the motor on my 2002 CR250. I started putting everything back together and ran into a small problem. When I put the kickstart pedal on the splined shaft it places it back far enough that it contacts the frame when you tuck it in. I pulled it off and rotated it (1 spline) clockwise. Now when you tuck it in it sits too low and hits the pipe. Any ideas? Is there a way to take the right side cover off and somehow rotate the splined shaft? Thanks in advance.
