Ok I was riding (96 yz 125) hit a couple trees and all of the sudden my kickstarter won't spring back up and itwill kick forward...bike still ran so rode a little more and then checked it out...I had to take my case apart and loot at the shaft...at the end of the shaft is a gear and then a spline...around the spline is a ring with a projection on it...my guess is this prevents the kickstarter from going forward...ok so the ring is broken and is weldable...so my question is when I get this welded is there any particular position it goes on (I forgot to look when I took it off)...and what is this piece called ...is it available somewhere as a seperate part...I could only find the whole shaft and the ring is pressed on I believe. THanks
VAnessa:think :think
