Badgadjit1 said:ya i pull out the carb parts and spray them individually.
and yes i am sure about the TPS.
and yes i have tried several different plugs.
I think what you are thinking is a TPS is actually a Fuel Cut Off.. That could be your problem.. Worth checking out.
Badgadjit1 said:but is there a way i can check the cdi with a multimeter?
Badgadjit1 said:What should i look for. I mean from the symptoms if it is a fuel shut off, that makes sense cause its starting on a pop and dieing out.
Like take it off the carb and what...
The powerjet carb on those bikes only goes into effect at high rpm. Basically, a solenoid triggers at a certain rpm and actually reduces the fuel. If the solenoid stops working, you will lose a little high rpm power, but it will not effect anything else.
Badgadjit1 said:http://www.dirtrider.net/forums3/showthread.php?t=138476&highlight=fuel+solenoid
after reading this, it doesn't seen that my solenoid would be giving me the problems i'm having...
Badgadjit1 said:ya i have one...its just not here..i have to get it back from a friend..
also..i have been looking for an aftermarket cdi for this..just incase this is the prob. do they exist? i can't find any. I found one on e-bay. do you know what the year range is on these. i found a 2002..
Badgadjit1 said:hrm...if you go to the aftermarket area for offroad bike they only offer cdi's for honda..i know i can get an oem...but they're so expensive..
Badgadjit1 said:ya..looks like 99 is alone...
