DirtBiker125CR1313
- Jun 25, 2010
- 48
- 0
I am replacing the right side crank seal on my 07 Cr125. I opened the bike up to get to the seal and before I even took the gear that is in front of it off I can see that the seal is not in the hole. :yikes: I need to know how far down I should put the new seal. I know not to make it touch the bearing but ho close should it be? Also I was going to put a little Belray waterproof grease on the inside and outside of the new seal. Am I correct that I should use the grease?
