farmerj, you're 100% correct - lowering the rear effectively increases the steering angle --which is what Jaguar has accomplished with the longer pull rods --that method starts you out with your swingarm in a more horozontal position. You also lose at least an inch of suspension travel and all too frequently feel that rear tire gnawing at the underside of your seat. The "wandering" that we experience with the KDX is due to oversteer -- The tire "Bites" and before you can correct, the wheel goes off in whatever direction it wants. By increasing the fork angle, it gives your arms a better leverage ratio by moving the front wheel into a less effective angle with respect to the ground. It's also called "slowing down" the steering. A steering damper accomplishes the same thing by mechanically resisting those side to side swings. Unfortunately by lowering the rear and increasing the effective steering angle, you exaggerate another even worse trait of the KDXs --understeer or washout.[which is what really irks me about my KDX] You'll be going around a fast corner in 5th or 6th and suddenly the front end goes away--not a confidence builder !! So how can a bike exhibit BOTH understeer and oversteer ?? Maybe we can get Jeremy of MX Tech to explain that one. [IMO, the understeer is due to improper internal valving --especially too soft rebound damping. Has anyone out there installed the adjustable rebounders and with what results?]
