Jul 25, 2005
171
i am pretty sure that I want the carbon reeds since they give the best response and are suppose to let you rev higher. I am pretty sure a woods pipe would do wonders for my bike especially were I ride. also once you get the carb mod . increase power over the rev range and more over rev. WIDE POWER BAND :aj:by the way go to this site will explain a lot.http://justkdx.dirtrider.net/200vs220.html
lepper
279
What I mean is, the author of the article didn't cover much at all on the 200 because he does not own one and probably shouldn't have commented on such. I do, I know a ton about the 200 and the article comes up very short on useful info for the 200 model.
May 26, 2005
105
I've got the rev pipe, power core 2 silencer, Boyseen rad valve and the stock carb jetted spot on. Jetting is probably the BEST way your gonna get good all around power. I ride mostly woods but in FL it's alot of deep sand so revs are needed. Don't think the Rev pipe kills low end like claimed, it doesn't. I can't compare flat out to a woods pipe as I don't have both. Also don't think the rev pipe is gonna make your bike scream like a 125 or 250 MX pure bred, It won't. What I did to get big bottom snap back was go to a 50 tooth rear sprocket. I can snap the front end up in 1st thru 3rd with no clutch. I don't care about top speed even though my handy dandy GPS will still read 68mph flat out. If you need more than 68mph I can't help you :)
strider80
177
My $.02:
I also ride woods in washington on my 200, I have the Boysen power reeds, gnarly rev, TCII, drilled airbox, rejetted, Steahly flywheel weight and a 50tooth rear. My bike seems to pull pretty linearly all the way up the revs, I am sure the 50tooth with the flywheel weight helps smooth things out. I never find myself wanting more low end, but my bike sure flys when I get up into the powerband, maybe I use the clutch enough that I don't notice the drop in lowend with the rev pipe? All I know if that when I grab a handfull of throttle I better hang on. And with your 220 you already have a fatter lowend, I would go with the rev if I were you to wake up the topend.
My riding buddy has a KTM 200exc and he can't believe how linear the power is on my bike, sure he has a ton of topend but it wears you out riding it on the pipe all day long. He can't understand why he is dog tired after a couple of hours. Eventhough I have a rev on my 200, it is still plenty smooth and ridable.
Green Hornet
837
I have a 220 w/rev, TBC2, Boyseen Power Reeds, NO Air Box Lid and a 35mm Carb. The pipe, Power Reeds & TBC2 really woke the bike up with no noticable loss on lowend. The 35mm carb just made it even better w/o noticable loss on lowend.
Jul 25, 2005
171
how much more technique does it take to ride the 220 on the trails with the rev pipe versus the torque. or am I just going to want the torque because it has the same powerband as the 220 already has, just more. THanks. :)
kdx220freak
Registered
Aug 23, 2005
321
i think i need to give you another one of my opinions. it seems like you want the rev pipe, so get it. I sure if you want bottom end you can put on sprokets or get some reeds. But then i would keep your 33mm carb on the bike for better bottome end.
kdx220freak
Registered
Aug 23, 2005
321
lets just say not many people have a woods pipe, most have a rev pipe. get the one you will need. If you will be going in 3 gear or less most of the time get a woods pipe if not then get a desert pipe.
Jul 25, 2005
171
now I know after thinking it through that I want a woods pipe and that I will bore out the carb to extend the powerband. i wnat top end but I dont want top end with a major hit to it that I will be constantly losing my bike over a cliff. I think carbon reeds bored carb wiseco piston and a woods pipe is what I need.
kdx220freak
Registered
Aug 23, 2005
321
well the tcII is the turbine power core II silencer. The other is probably a silencer also. The weisco piston is a saftey thing so your kawasaki piston does not blow up in your motor. But it should also raise your compression which will give you more power.
bleeb
10
I ride logging trails & tight woods, but I also burn it out in my fields. Right now I'm running a Dynoport Big Volume pipe, a Steahly flywheel weight and a 12T front sprocket. With the DP pipe only (no other mods) I noticed more bottom end, smooth powerband, and a bit more top end. I think the DP could be explained like a hybrid - 1/3 Rev and 2/3 Woods pipe. When I put the 12T on, the bike pulled like a tractor. I put the flywheel weight on for downhill anti-stalling purposes, a some lugging improvement, but I didn't really need it to smooth out the powerband. I'll probably get reeds next, because I can't stop buying stuff for the bike.... :ride:
