budhoot
30
How much tranny oil am i supposed to put in a 2002 YZ125 i cant find it i dont have a manual and i just bought this bike it says 650cm3 right next to the oil fill cap. What does this mean? If anyone can find our or tell me how much I am suposed to use that would be great!
-Bud
Kevin003
237
Considering you own a 2stroke the oil that lubricates your motor is mixed in with your gas. With that said that number stamped on the side of the case is for your trans fluid. Therefore you should put in 650ml of fluid.
budhoot
30
ya im talkin about transmission fluid it says 650cm3 on there so therefor that does mean i put 650mL of transmission fluid in there when i refill it right?
FruDaddy
2,854
Yes, maybe a little less depending on how much residual is in there after draining it.
Mx yz 219
5
go to your local bike shop and buy a Ratio Rite cup. it has all the measurements on it and you can't go wrong. shouldn't cost more then $5.
