Guys!!! I need your help, will somebody teach me how to install the torque ring? I will try to build 1 for my kdx 200. I'm from the Philippines and its difficult to order from here. Pls give me some tips on how to install it. I have a 1990 kdx 200 thanks!!!
It fits into the cylinder between the pipe and the cylinder. No real 'tips' required. Remove your pipe, put in the ring, put your pipe back on.
The FRP website doesn't say, but I would suppose it to be a good idea to use an oem copper gasket on either side. That's probably not critical, but having a heavier (than aluminum) metal vibrating against the aluminum of the cylinder can't be a good thing.
Doing a search with the words 'torque' and 'ring' would have shown you this:
