I need some help. My rear disc is toast, but, with any eight year old well-worn dirtbike, the steel bolts have seized in the aluminum hub. How do I get these out? I can drill the heads off, but then what? Drill and re-tap with a larger bolt? I don't think I can go larger and find something that still will fit. What are my options?
Here is the bolt-heads on the "front" of the disc:
<img src=http://x5000.com/body/misc/boltHead.jpg>
Here's the back of the disc where you can see the bolts on the backside of the rotor. There *might* be enough room to throw a nylock nut on there, but I'm not 100% sure that I want to do that.
<img src=http://x5000.com/body/misc/backDisc.jpg>
By the way, the bike is a bit dirty. Didn't clean it after I grenaded it out in NM this past weekend.
