rmrider45
171
IndyMX said:
427-11 is just a part number.
http://www.jtsprockets.com/52.0.html?&L=0&sel_uid=5427&p=
There is no 427 chain size..
As far as I know, dirtbikes usually only use 520, 428, 420.
But why would you want a 11 tooth sprocket? that's a bit small..
so it will work?
i wanted a smaller sprocket to get the feel of the gearing before buying a bigger rear one
i looked at ratio charts and with a 11 is just like adding 4 teeth to rear
Chili
Apr 9, 2002
8,062
17
IndyMX said:
I'm betting it will..
Given how JT cross references each year and bike a part works for I'd be very reluctant to try, especially since it's a $10 sprocket. I'd chalk it up as a loss or ask the seller to make it right.
rmrider45
171
well it fit :) the chain is on its way out anyway.. i am just doing this to get the feel of it. if it works ill get a bigger rear sprocket.btw hill climbs like i do will stretch the chain out no matter if it has a 11 or a 12. i am always adjusting slack out of the chain...
