Is a kx100 too small for me?
TC21
5'8" 140
pretty aggressive hit jumps (10 feet on xr200)
I plan too ride with friends hit jumps on trails and race on trails with friends
4 years on xr80 and xr200
with friends on trails
yes
no preference
CRAIGSLIST!!
not too much 800 to 1100
no
11) Your age?
the big 14
The question says it all. Is a kx100 too small for me or is it just right because I have never ridden a two stroke?
Thanks :ride: :rotfl:
I think that it's a little too small, a 125 2-stroke with a shaved seat would be better for you.
TC21
I have found a 1996 kx100 for 1100. Has FMF pipe, it has the spark arester, fresh plugs, tranny and gears with new lube and oil. Tabs, orv. It also has a newly rebuilt engine.
Is this a good deal?
TC21
So 5'8" is too big for a kx100. One last thing, what is the power comparison to the xr200? Does it have more or less?
The KX100 would certainly have more power than an XR200. A 125 will blow it away. I am 5'8" and easily fit a full size bike. The mini bikes are all too small for me to do more than play on. The only reason that I even suggested that you should shave the seat is because you said that you will be riding trails, and for that you might want to be a little closer to the ground when you put your foot down.
TC21
I have found a great bike in great condition. It is a 1994 KX125 for $1000. It has Pro Circuit exhaust, Pro Action Suspension, Gold DIDO chain, Hinson clutch, extra plastics, runs great - used rarely last 4 years.
Is this a good deal with all of the aftermarket parts? Would this be good for me?
i wouldnt buy the used rarely last 4 years.
if its only 1k for all those after market parts its gonna need work considering exhaust (depending on what kind it is) can run up to 400 for a muffler
Only the thumpers, buddy, a 2-stroke pipe retails for around $230, and another $120 for the silencer. When selling a bike, you can't add full retail to the value and expect to sell it. The seller is probably throwing the extras, that s/he won't need anyway, to sweeten the deal and further entice prospective buyers.
Sight unseen, it sounds like a good deal to me, as long as it runs well, and doesn't need more than routine maintenance. You'll probably need to grease all of the bearings, and lube all of the pivot points. Other than that,check the condition of the tires and sprockets.
