upnorthbacon
- Jan 28, 2005
- 35
- 0
2000 kx250 just purchased. How do I check the crank bearings need replacing? Mostly curious about the bottom bearings? I took the pipe off and can move the crank slightly back and forth through the case? Is that normal? I'm assuming I have to take the jug off and measure something to know for sure? What special tools will I need if I buy the hot rod kit which comes with the crank?
