my 1995 wr 250 2 stroke manual also says to use motor oil but i always use belray gear saver 80 weight oilrmc_olderthandirt said:The manual I have for my two strokes (Yamaha YZ125 & YZ250) says to run 10w-40 in the transmission.
A car will have a different oil for the transmission thant the engine. If the car has an automatic transmission it will use a fairly thin oil that is blended primarialy to benefit the torque converter and the friction bands.. A standard (manual) transmission will typically use a much heavier "gear oil" as there are no friction components and minimizing metal to metal contact in the gears is the primary objective.
The transmission on a dirt bike has requirements between the "gear oil" of a straight gearbox and the specialized requirements of an automatic with torque converter. The clutch operates in the oil bath so you don't want to use an oil that will completely prevent friction.
Rod
cr2012 said:i have an old 83 honda cr60 i was wondering what kind of motor oil i should use in the transmission?
