Jason81
68
Does anyone know anything about Suzuki JR 50's...
I am looking for a wheel base spec.
My kid ran it into a rail road tie (you know how they just jump right out infront of you like that) and it appears that the frame is bent as the fork angle is very steep and I have checked that they (the forks) are straight. I am also hear that there is a mod that can be done to make it a 2 speed?. I am getting him a KTM in the spring but would like to fix the JR as I am giving it to my nephew.
Thank you
Jason Laney
Darryl K
50
Jason, I believe the wheelbase is 34". This is not gospel but I believe it to be in the ball park. I am not aware of a 2 speed kit for the bike but there may be one out there.
I purchase a KTM sx50 Jr. for my 7 yr. old this summer and it is a great performer. Words of advise though: Buy plenty of thread lock compound and an assortment of replacement bolts....it WILL rattle everything loose eventually. I have also made rubber insolators for all areas of attachment for the pipe. So far I have had the pipe body and a bracket rewelded and the bracket on his silencer broke off yesterday while ridding. The overall quality of the Japanese bikes is not present with the KTM but the performance level of the engine and suspension are considerably greater that that of the XR50, Jr50 or PW50 etc..:)
agitt73
1,078
on the two speed thing it only has high gear right now
all you have to do is take the clutch cover off and there is a gear position arm
grind the notch biggerin the opposite direction hard to explain but simple to
see with clutch cover off
mx547
Ortho doc's wet dream
4,785
103
what year is your jr50? i have a '81 jr50 parts bike. let me know if you end up needing a frame. i don't doubt that they are all the same.
Jason81
68
MX
I fixed the frame this past weekend and now the front suspension works great for him... He is jumping and getting close to a foot of air. Not bad as he is now attacking a small set of doubles that I made at the exit of a turn for me to play on... Kids always make me look bad:)
