Well folks, I got a call last weekend from my riding buddy "Randy" who was ECSTACTIC about having some time off - ALL DAY MONDAY!!!!!! We made the plans (consisting of - HEY WIFE, I HAVE BEEN REAL GOOD......) and set the sights for a Sunday afternoon depart to the east side upper Lower Michigan area. We found our way (in the dark) back to the spot where we had left off on a previous ride (it is a spot where myself and 2 other riders met up with KTM mike and TOOOObig4akdx on our venture up that way). The place is located just above Fairview and we camped right where we left off (right on the side of the MCCCT)!
We set the tent up in the dark (car lights are great) cause it was 1 AM... BEAUTIFUL night, about 55, perfect for sleeping!!
Got up and on the trail by 8:30 am and headed north..
I had remembered how "rocky" the trail had gotten toward the end on the last ride so I took the time to redo my tire pressures before I left (I also redid Randys but he didn’t think it was necessary). I normally run 8 in the front and 4 rear (lots of sand in our areas), I went 12 and 7 for this ride and GLAD I did. We no sooner got on the trail and Randy started throwing rocks at me :) He is riding a "little" XR200 now cause the dummy sold his street legal CR250... The XR seemed to be right at home in the "stubble" as was my "legal" KX500 with the flywheel weight!! We both wondered how the XR would do as we are both very much used to bigger bikes.
Gotta tell you that the little "wonder machine" really faired well!! The type of terrain up there is, what I would, call XR country! Tight (at least tighter then the cross state connector was), rocky, some low sections kinda muddy, and very little high speed chasing!! The ride North to Atlanta was GREAT!!!!
My KX LOVES high hills, especially the knarley stuff that a lot of bikes run out of bottom end on~! We found some REALLY rocky, eroded out nasty stuff that the KX was OUTSTANDING on! 2nd gear just above idle and the thing is like a John Deere tractor!! WHAT A BLAST!! The XR didn’t fair as well on some of the real high knarly stuff but, after all, it is just a 200!!!
A lot of the trail up there looked like it was almost virgin!! I think KTM Mike has got a hidden secret about that area - how about it MIKE, are you trying to keep that area unspoiled?? I think I saw “Young Teds” ol’ Penton tracks on it from Labor Day Weekend and that was a couple weeks ago!! Sheesh, don’t know body ride up there??
We had lunch in Atlanta at the bar/grill closes to the trail - GOOD FOOD!! And went right back to work (didn’t even bother getting gas – my 3.8 gallon Clark tank showed almost ¾ full). If you happen to get up that way please be on notice that the Sheriffs Department is right on the way into town so take it easy (we didn’t get stopped but the front end of that KX gets REAL light when it’s on pavement,,,,,).
We hooked back up on the MCCCT and headed toward Onaway. Rode a real fast pace in this section and had a blast. It was dusty so I led (usually Randy does cause he has a way of always showing up with NO goggles so he can lead :)) and kept a good distance between the KX and the XR. I would stop at the intersections and listen for the XR’s thump and then continue when I knew my ridin bud was ok…. Randy said this worked GREAT as he was able to keep the XR pinned for LONG periods (one of the blessings about riding a bike to small for you) and it was a RIOT!!! We crossed “33” going into a "Bear Den" area (or something like that) and I stopped to check my fuel – GOOD THING I DID!! I was down to about 1 1/2 quart of fuel and told Randy we needed to find GAS!!! I looked at the CCC map and it showed the closes station south on 33 – other choice being Onaway. We went south to find the station burned down!! I asked a lady living behind the station where the nearest fuel was and she said either Onaway or Atlanta – same distance. I told Randy that we should go north to Onaway – it just didn’t make since to me that Atlanta could possibly be the same distance – good thing we went North cause she was WAY wrong and I ran out of gas at the top of the hill that drops off in Onaway!! I found out that the tank on my kx gives the bike a total mileage of 93!!! I was VERY impressed!!! I only had to push about a ½ of city block by the time I coasted down the hill :)
We gassed up and went back to the corner where we had dropped off the trail. From this point on the trail was mostly two track and gravel all the way up to Tower and the little XR didn’t really care much for the “higher speed stuff. Randy told me that I needed be more careful about my high speed “wheelies” – he said he was concerned about me cause I like to cross my front wheel side ways while I am on the back wheel (showing off)! I know for a fact that he was actually just jealous because his XR was too putsy to pull the front in up at 50 + :) :)!! I say this because when he had his CR and before that his BIG BORE XR we would ride side by side on the back wheel at those speeds and he NEVER complained!!! After he complained I cooled it down just to be nice…..
We went thru Tower and headed North to the point where the trail was suppose to make its western turn toward Indian River. ###PLEASE NOTE### At this point the trail is VERY poorly marked. We spent about 45 minutes trying to figure out just exactly what happened in this area.
Here is how I explain what happened: The MCCCT has a “stub” section that leads to the “Red Bridge” loop (page 32 of last years map book). Now don't get me wrong, that Red Bridge trail is AWESOME (when we go back up to finish the MCCCT we are also going to ride this whole loop!!) but it appears by the signage that the MCCCT actually ends at this point!! There are NO markers indicating a “westerly” trail on the MCCCT! There is an old railway bed that had us “spoofed” for a while, the trail markers indicate that you need to follow the Red Bridge loop for a while – not so, although this loop is REALLY awesome. cant wait to go back!! We didn’t figure it out until we started just following 2 tracks and came across the markers again….
At this point in the trip I stopped and told Randy that we really should be heading back toward “camp” so we could make it back to home before 2 am so he could get up and go to work at 7…. He sadly agreed!!! We headed back attaway, by the time we got back to the Jeep it was just before dark and getting pretty cool!!!!! I went right to the Jeep and got my sweatshirt out, went back out (hey Mike, that’s little “rock quarry” we found you guys at is a REALLY fun play ground!!!) and rode till dark. Total miles for the day was well over 200!! GREAT RIDE, GREAT DAY with A GREAT BUDDY!!!
That’s the way it went on this one guys!! Get out and ride when you can this fall!!
Carpe Diem
Woodsy
Carpe Diem
Woodsy
