roosteater
- Dec 27, 1999
- 216
- 0
Hey all,
I'm going through the top end on my 98 KX 250. It, of course, has the KIPS exhaust valve system. I've run into a problem that I've seen before, but I'm still uncertain how to conquer.
This is in regards to the actuator arm, which I think is termed a "pinion shaft." To fully disassemble the valving system so that all parts can be cleaned, one has to remove a small, gold-colored, aluminum, phillips-headed screw. This screw holds this pinion shaft in place. Once you remove the screw, the shaft pulls out and you can get the last remaining valve parts out of the cylinder.
However, as the screw is made of really weak aluminum, the phillips head strips very easily. This one already shows evidence of wear and is very tight. I'm fearful of just cranking on it as I'd probably just strip it out the rest of the way. So, I'm thinking of heating the area up with a torch to loosen it up a bit. If not, it seems that I'll be off to the machine shop to have it drilled out.
Questions:
1) Any advice on how to get this bugger out?
2) Why do these moron engineers use such a crappy fastener on a spot where the fastener is naturally going to tighten over time?
3) What can I do to avoid this crap in the future? I'm thinking of finding a substitute fastener with either a hex head or an allen head that won't strip out when I have to remove it in the future.
Questions:
