KDX 200 Stock Sprocket and Chain sizes
MADisher
Grand Data Poohbah
377
I'm a little confused.
I'm about to order a new chain and sprockets. I understand that the stock gearing is 13/47
I'm going to order that again and probably a 12 for the front as well to give that a try. I have a O-Ring chain currently that is starting to kink a bit. My confusion is multiple online stores claim different sizes for the chain. 520-108 or 520-110.
I realize I coudl buy the larger 110 and take a couple links off, but that is a $@$@% with an Oring chain. So if I need a 108 I want to order that.
-MD
BRush
1,099
Stock chain size for the stock 13/47 ratio is 108 links. My 13/50 setup takes 110 links. If you are planning to drop a tooth on the countershaft, there is no good reason for going to 110 links. You probably want to stick with the stock chain size.
MADisher
Grand Data Poohbah
377
Thanks, I checked my sprokets and I'm currently running a 12/47.
I've ordered a 12/47 and 12/49 to play with I think 108 will fit then which is good because that's what I odered as well.
thanks for the follow up.
-MD
