Hi, I am 5'6" and all I did was cut the seat foam down by about 1 1/2 inches
It sure helped a lot, and I reused the factory seat cover so time was my only cost. good luck.
You mention longer pull rods, so you're familiar with that. What is it you're asking? How they work? If they work?
Check the koubalink website for some more info.
Ask a more specific question?
5'7" isn't much on the short side. If you're new to dirtbikes, some time spent getting used to the bike will help a lot. Being able to easily touch the ground will come to be less of a need.
NOT being able to touch the ground will likely be an advantage, anyway. Developing that habit isn't a good thing. A good way to get hurt for one. Getting to trust the bike (when you get the suspension to work as it should) and knowing it can save your arse more often than not if you just LET it is a good thing.
Just FYI....I'm 5'-5" and have a 220 with no lowering mods. I just have to slide my ass off to one side when I stop. Now as far as slow technical riding, I have found not being able to dab my foot down does pose a problem. I've picked myself up more than once due to short legs.
It doesen't matter in the end as long as I get to ride. :aj:
I'm 5'7" myself and I talked to a Factory Rider for Husky and he had his subframe cut down and welded back together, he tells me RC and others do the same thing. Because the sub frame only holds the rear end up. I would suggest checking with your local shop to see how much is too much.
