Kick starter problems (89)
GAT
5
I have an 89 200 and have had problems with the kick starter "slipping" or "missing" when going to start the bike. I have had the bike apart and replaced the spring that pushes on the gears to grab in order to turn the motor over ......but it still wants to slip.
Thank you
Greg
bradmo
7
I just baught a 96 kdx200 and have exactly the same problem. Did you manage to fix yours? What did you have to do?
Regards
Brad
bradmo
7
Thank you
Greg
Hi there, I have just baught a kdx200 and have exactly the same problem. Did you fix yours? What did you do? Please help!
Regards
Brad
Grunta
8
pull it apart again and you will find that you will have a nik on the crank plate which wiil stop the gears meshing use a knife stone to smooth out the mark and this will fix the problem.
