Well, you all helped with Question #1 re:chain tension, so I am hoping for more help with setting up the shock suspension.
I know that you are supposed to set the shock up for 35 mm static sag, but I read (and it is true) that with the bike on the stand, you can step on the rear wheel and you get another 10mm of sag!!!
So is the 35 mm static sag at the 'free-hang' position or with the foot on the wheel pressing it down?
And does anyone know of lighter shock springs than the PDS5 or 0, which are apparently the same? I only weigh 122 lbs.
