I'm having trouble with my KTM 520 MXC, I can't keep the front end under it!
There are two major symptoms, fork dive and pushing in corners.
It's diving badly( 3 or 4 inches ) the front anytime there is a transition
that causes a weight shift forward. It is really killing me on steep
technical descents where you have to transition from no braking to braking
based on available traction. I'm talking one finger, ever so slight braking
causing the front to dive, then the it stops suddenly after 3 or 4 inches of
travel. This is not confidence inspiring, to say the least. I thought
maybe it was just me so I let a couple of friends try it (better riders than
I) and they commented on the same thing!
I'm think I'm seeing the same thing in the flats/corners as a "push" in the
front end, it's very vague and pushes badly in the corners.
I've tried slowing the transition by increasing compression in the front, no
help. I dialed in enough compression (over several rides) that I was not
getting to the last 4 inches of travel even in high speed trips through the
whoops. The bike would still dive, even on transitions from climbing to a
ridge with a tight turn at the top. I've tried slowing down the rear rebound
thinking that maybe the shock rebounding too fast was causing it. No luck.
As a "check" I went back and rode some of the same descents on my '02
YZ250(stock valving .46/5.4 springs) just to see if it was a "skills" issue
with me...I didn't have a problem with the descents on the YZ or pushing in
the corners for that matter.
The bike has been revalved by a local shop and has a .45 springs in the fork
and PDS3 in the back. I'm 6'4" and 220 plus gear. Ablity wise, I run with a bunch of
Vet Experts but I'm the "slow" guy in the group. I've placed in the top 5
Sr. open novices in D-37 races.
I'm on the stock rubber M77/78's, ( 16 F/R PSI for desert) They wear well
but I'm starting to think it's part of the problem with the High Speed push.
I've read lots about changing out triple clamps on KTM's - 22's, 18's and 16's! I
guess I can see the 18's and 16's helping bring the front in so there is
more weight on the front to help it hold? I guess I don't understand the
22's at all, wouldn't that make things worse?
Any ideas on sorting this thing out?
