Gitzen
I took my top end off because it filled with antifreeze, then I put it back on and everything worked and it kicked over. Then when i went to start it up about a week later the kickstarter is stuck and will only go about 1/4 to 1/2 way down and not kick, what would be the problem and how would i go about solving this problem.
Thanks!
Justin-
griffbones
329
Sounds like it maybe full of water again and hydrolically locked? Or maybe you stuck a piston? Take the top end off and look, that is the only way you will ever know.
pull the spark plug. if it is hydrolocked it will turn over. if it still wont move it is siezed. good luck!
