Ugh... my engine locked up; turns out it was the connecting rod bearing on the crankshaft; it's frozen tight. I have it apart as far as I can at this point (don't have the flywheel puller). Once I get the flywheel off I don't have a problem splitting and reassembling the case (done it before), but what's involved in separating the crankshaft and replacing the bearing? Is it likely the crank and/or conrod are shot too?
Is this a common problem? I got the engine (not on a bike; it's on the KX100 paramotor discussed in this thread) used; dunno the history but it looked pretty good though I only have about an hour of running time on it.
-Dana
-Dana
