RM_guy
Moderator
7,060
214
North East USA
Sorry about the misinformation. I got that exploded view off of BikeBandit for a '99 RM125 but there were 3 different exploded views. This is the one you want and I guess you do have to split the cases. It's still not that bad of a job but is more than an hour
99rmRACER
22
alright so im almost there i just need to remove the magneto rotor, but unfortunatly i dont have a rotor holder. is there any way besides using that to get it out>? is there any trick like the penny thing with the clutch?> thanks so much guys you have helped me sooo much!
darringer
1,029
I use a wooden broom handle wedged through the back rim and the swingarm. If the rear sprocket has holes in it I put it through there. Put the tranny in 6th gear and remove the magneto bolt. You still need the puller for the mag, but it's not expensive. This has always worked for me and has never caused any problems. Good luck.
