does anyone know where i can get a lighting coil for a 95 ktm 300 exc. oem wants $485, or is it possible to have it rewound. the factory piece is the whole ignition assembly. all i want is for the front headlight to work
I assume you have the sem ignition as I did on mine. try Ricky Stator or trail tech to see if they will do a rebuild. If not i think you have no choice.
