Little help please, looking to buy XR-250
70 marlin
2,963
for my teenage son. also I like to be able to ride it my self. here's my question. you can use xr 400 spring's on kdx's. can you use kdx spring's on xr-250's, as I have a spare set of KDX race tech spring's for my son's weight I did a search and and found a ton of xr-250 stuff, but no info on my question. thank you very much. :confused:
VintageDirt
Baked Spud
3,043
9
XR250 has 41mm Kayaba forks, XR400 has 43mm Showa forks, and KDX 200 has 43mm Kayaba? forks.
So while I don't actually know the answer to your questions I would say you cannot use the KDX springs in an XR250. But, you might be able to use the XR400 springs in the KDX.
I bet if you ask Jer in the suspension forum he'll know.
Sheesh I've had to edit this post three times and I'm still not sure I said what I meant. :confused:
70 marlin
2,963
XR 400 spring's :thumb: are the trick for kdx's! ya, I might run it past jermy forum. after the XR people advise. :worship: :thumb:
VintageDirt
Baked Spud
3,043
9
Oh brother. My reading comprension is at an all time low. Guess I'll have to take that Evelyn Woodhead sped redin refresher course. :) I see from your original post that you already knew that the XR400 sproings will work in a KDX. :confused:
Even though I can't read too good, I still don't think the KDX schpringens are gonna fit down the hole of the XR250 forks. I'm going back to bed.
