ftw666 said:yea im having a hard time finding one and i keep getting outbid on e-bay thanks guys
I doubt any of that will work. There are a lot of forces being applied at that joint and you need solid metal to suport it.TWRT said:I put some rubber o-rings on the shaft that fits inside the kick starter arm and greased it up. It helped some, but they need replacing from time to time and sometimes get caught by the bolt that screws in to hold the arm on. I am going to try some carefully placed JB-weld and see how that works. I also stretched the spring out so that the ball bearing would push harder on the shaft and help keep it from moving.
