If you have access to a welder you can try a old trick,remove the clutch release lever from the clutch cover and lengthen the arm the cable attaches to,not the small swivel piece but the main arm attached to the shaft, approximatly a 1/4",measure first if you can add that much for cable alignment and clearance etc etc,I just did this on my 94 and its about half what it used to be.
