Mikuni TM33 Pumper on XR250 ?
TR
179
Has anyone fitted one of these to an XR250 ? How well did it fit ? Does the throttle linkage on the right side have sufficient clearance ?
What sort of cables are you using ? Push/pull, modified standard or other ?
Was the project worthwhile ?
Thanks in advance
TR
mafols
269
The pumper carb. has made more difference on my bike than any other mod. I've done so for. A CR throttle works well and I've recently replaced my stock air box boot with a XR400 boot....much better...goes on easy and less restriction for the air flow...I used to dread taking off my carb. because it was so hard to get that stock boot on.
TR
179
mafols, have you got any pictures you can post ?
What engine mods have you made and what was the jetting you ended up running ?
thanks
TR
FRESH VIDEO
