We all know oem clutch can't be beat,I was in a pinch and put a moose clutch in my 03 KX 250,I put a lot of hard time on the oem a good 2 yrs. The oem steels were not warped, and measured fine,but they were discolored blue from heat. The fibers were at the service limit 2.8mm.Springs measured 34.9mm standard is 35mm service is 33.6.
I measured the moose plates and springs before installation,the plates really susprised me, they measured the same as oem standard. The springs measured 34.4mm about .5 mm less than standard. I threw them in even though my stock springs were still good. About my 3rd time out at the track roughly 6hrs time on the clutch total,I was getting bad drive coming out of sand corners I passed it off as wheel spin,but then she really slipped.
Clutch basket fine ,center hub fine,pressure plate fine, moose plates fine. I measured the springs new they were 34.4mm they now measued 33.5 all except one which measured 34. In 6 hrs time the springs dropped. .9mm and they were already a .5 mm shorter than oem. I think DP makes them I was in a pinch and put a moose clutch in my 03 KX 250,I put a lot of hard time on the oem a good 2 yrs. The oem steels were not warped, and measured fine,but they were discolored blue from heat. The fibers were at the service limit 2.8mm.Springs measured 34.9mm standard is 35mm service is 33.6.
Clutch basket fine ,center hub fine,pressure plate fine, moose plates fine. I measured the springs new they were 34.4mm they now measued 33.5 all except one which measured 34. In 6 hrs time the springs dropped. .9mm and they were already a .5 mm shorter than oem. Dp makes the springs for moose,but I am not sure who makes the plates for moose.JUNK JUNK JUNK!!!!!!!
