Even the VERY nice motion pro separator, you need the correct size case bolts. Get as many bolts into the cases, and use the center draw bolt to push off the crank. Hit the counter shaft once in a while with a dead blow to keep the separation even. Honestly, a 1/4th inch plate of aluminum, attach 2 draw bolts off a c clamp, and match all the case holes, would work even better!
