Need to start riding!
Hey all, my first post.
1) your physical size. 5.8ish 160 pounds.
2) How physical / aggressive are you ? about 8 out of 10
3) what do you plan to ride- MX/SX tracks, woods, fields with friends or ????? Woods, fields, friends.
4) Do you have any riding experience? A little. I can shift. :)
5) Do you think you will race ? I doubt it.
6) Are you mechanically inclined and will you be doing your own bike work? Mostly not
7) Do YOU have a preferance to a brand/ motor choice (2 or 4 stroke)? no
8) Do you have a dealer close by your home that you might use and what brand(s) does he carry? all
9) How much ($) do you plan to spend on a bike? $3000
10) Do you live in California? Nope
11) Your age? 22
12) anything else that you think would help form an opinion. Want to get started ASAP. No idea what it is what.
If you wanted to go that rount (4-stroke) then a CRF230, or a ttr-230, or a XR 250 will be fine for you...
But if you wanted to go 2-stroke, then any 125 2-stroke will be good..
From the bikes i listed they are both about the same in maintenence. And they are about the same "speed" the 2-stroke might be alittle faster, but you need to be on the gas, or in the higher RPM's, and the 4-stroke hase a lot of low end power, and you dont have to be in the high RPM's.
The 4-stroke will weight more than the 2-strokes.
Now if you wanted to go new age MX 4-strokes like the CRF250X, or a WR250F then that would be great, just a wee bit bigger than the 125 2-stroke, but it would require alot more maintenence. More often...
But you will be happy with anything listed above...
flyingfuzzball, i bet you have not ridden a DRZ400 or a XR400 befor have you. They make smooth hareless power that is great for a beginer ridder in stock form.
yea
the 2 stroke engine produces more power than the 4 stroke
the 4 strokes have more bottom end and the 2 have more top end
If I were you, I'd start on a bike such as a 125 two-stroke, some are:
Yamaha YZ125
Suzuki RM125
Kawasaki KX125
Honda CR125
The bikes are good for beginners because they have power, but they also don't need the upkeep that four stroke will have, and considering you aren't "mechanically inclined" this would be a good decision. Less money you'd have to fork out to pay for fixes.
if 2 strokes make twice the power then what is wrong with the 125 and 250f in the same class :P
also 2 strokes are easier to work on if you need to crack fix something.
flyingfuzzball, you might consider the way a 4 stroke makes it power in comparison to a 2 stroke. In acuality a 250F and 125 almost make the same peak HP but the 125 has no bottom end. So, unless you keep the 125 in its power the bike is no match for a 250F near the bottom. http://www.maxpower-engines.com/big-bore-kits/yz167.htm
Here is a great example of what the power looks like. Even with the ilegal 167 kit it still only makes the bottom of a stock 250F. Now if you tune the 250F you might even might want to give up while your ahead.
i was joking around but yea i know.
the differences are crazy. it should be more like a racing 230 or even 200 four stroke.
but thats going off topic
