RM 2 fif T
- Jul 17, 2004
- 20
- 0
I recently put a new top end in and everything seems to check out fine. The compression is great and I replaced all the gaskets. For some reason though, now when i go to fire the bike up it fires up on the first or second kick then it shuts of right away. If i slowly push the kick starter down several times then give it a good kick it fires up then stalls, this also happens if i remove the plug and kick it a few times then replace the plug. The mix is right so i doubt its that. Could it be a carb problem now? or something else? Any ideas on this would be appreciated.
