kxrider125
- Oct 4, 2003
- 40
- 0
Could some one explain how the cluch system works on my 85 kx 250.
I knew i needed a new clutch kit so i took my cover off and my pressure plate and took the friction plates and steel discs in to the local 2 stroke shop for inspection.He said they were worn but should last a little longer.I put everything back together the way it came out but now my clutch doesnt work at all and my bike has no power at all..it just winds out when i give it throttle,almnost like the clutch is partially engaged and there is no difference when i pull in the lever,it does nothing.Its a pretty easy assembly so i am quite sure i put everything back together properly.I am waiting for new plates etc,but am wondering why this is happenning. :think:
