During and Enduro this weekend I took a creative line around a creek crossing bottleneck. Bad decision on my part. I went over the bars and my 98 220 got COMPLETELY submerged.
I pushed the bike to the edge of the creek bank and pulled the plug and wrung out the air filter. I kicked the bike over like mad to try to get the water out of the cylinder. To make matters worse, as the air filter was off and my air box totally exposed, a rider went by and in doing so, filled my air box with loose dirt. I was never able to get my bike started.
Back at camp I pulled the plug again and turned the bike upside down and worked the kicker up and down several times. I was amazed at the amount of water that came out of the cylinder and the silencer.
After spraying WD 40 into the cylinder and replacing the plug with a new one, the bike began to fire and almost started. In an effort to avoid further damage to the cylinder I decided to wait until I got home to clean the carb and air box before I got the bike running.
Here’s where my problems start. Thanks for sticking with me so far.
Once I cleaned the carb and air box and tried to start the bike, I got no compression whatsoever, even with the wash plug in the silencer, it feel as though there was no plug installed. I was easily able work the kicker down with my hand.
What puzzles me about this whole mess is that out at camp the compression was good and the bike almost started. After cleaning the air box and the carb, I’m getting practically zero compression.
I am in the process of tearing the bike down in preparation for a new top end. I think it is a forgone conclusion that the bike will need it.
Do you guys think a new top end will solve my compression problem or do you think I will also need to replace my crankshaft oil seals? Could it be anything else?
I’ve never done a top end before but I feel with the information on this forum I can handle the job. Getting into the bottom end for the crankshaft seals is an entirely different matter. I don’t believe I can handle that one.
I welcome any input that you might have as to what may be causing my compression problem. Also, any advice you have for fixing the problem would be greatly appreciated.
Sorry for the lengthy post. I tired to be as thorough as I could in explaining the situation.
Regards,
Chuck
Regards,
Chuck
