I just picked up a 93 RM250 in a few pieces. Nothing too terrible, but it has a new cylinder sleeve installed and needs a few minor pieces to stick it together. I think I have a problem with the new sleeve though.......
The original cylinder head is sealed by 2 o-rings, but the new sleeve does not have an o-ring groove. The sleeve also stands about 0.1mm proud of the 'deck'. I have searched the web to see if this is normal, maybe an improved way of doing things, etc, but came up with nothing. I suppose using a copper gasket I could obtain a pretty good seal without the small o-ring, but if it isn't normal practice then I don't want to mess about - I'll get the groove cut.
Thanks for reading and if you know the answer - groove needed or not?, please reply!
David in NC
David in NC
