I just got a 95 rm125 and was wondering where the oil check bolt location is for the crankcase oil. I haven't recieved my repair manual yet in the mail. Thanks for your help.
If it's a two stroke it's not going to be crankcase oil, but the gear oil for the gear box.
On my brother's bikes, an 01 and an 03 yz, the check bolts are always on the clutch side (right) about halfway up the clutch cover. the bolt is usually a hex bolt with a phillips head as well, so you can use an impact driver or a wrench to remove it.
I hope this helps :D
