sparkysakitas
1,079
ok i want to change oil in bike but have a little problem
i dont have the book yet its on its way. where is the oil drain bolt i cant seenm to find it
although i think i know where it is but dont want to just loosen bolts. there is a bolt on the shifter side down low just above fram is that it ? thanks guys your the best
sparky
Chili
Apr 9, 2002
8,062
15
The manual states to remove the fill cap, the TDC plug and the drain bolt. The drain is as you stated directly under the shifter, the TDC plug is the most forward of the engine plugs. Oil capacity is 1400 ml for oil change and 1450 ml for oil and filter change.
