2000rm125
5
i have a 2000 rm125 and the is oil coming from the muffler i have tried tuning the air screw and changed the filter in the muffler but that doesent seem to help should i change oil ratios right now im at 32:1???????? if not that any other ideas?
mkelly04
196
Let me be the first to say this, do a search for jetting.
Also, buy a manual for the bike. It should give you jetting specs for your location.
2000rm125
5
well i have a manual for my bike and i have tried the whole jettting thing and it dosent seem to help the oil still leaks out.
mkelly04
196
If you have oil coming out then your jetting hasnt been figured out.
What color is your plug when you pull it?
a454elk
Mexicutioner
7,538
18
If you run at 32:1 and only putt around, it'll spit oil. 32:1 is great for the track wide open but at slow speeds, it'll load up a bit.
2000rm125
5
im not sure about the color of the plug right now i havent riddden it in awhile casue im trying to sell it but i wanna fix this problem before i do. but when i did ride it it dident foul any plugs and i did ride around the track slower than most cause i was a beginner so that might be the problem i was just not going fast enough. and yhea mabey your right the jetttting isent right ill mess with it see if i can fix it. but will the jetting help if im going slow??. cause mabey the jettings right im just going to slow?? idk
and its a fresh top end i had to get it bored and new piston when i bought it
VintageDirt
Baked Spud
3,043
9
Chit mang, yous muffla bearins is chot, fo sho.
I shouldn't of said that but I figure wtf
2000rm125
5
was that english???
sorry guys when i said muffler i ment exhaust.... got my words mixed up
DougRoost
720
2000rm125 said:
was that english???
I trust you meant you repacked your silencer. That's a good thing since it could have been oil soaked due to prior rich jetting. You've clearly got more jetting work to do to lean this out properly if you have that much spooge coming out the end.
loge88
26
Yeah im having the same problem withmy bike and im also a beginner. Im gunna try to change my gas mixture to 40:1 and c if that helps. Hopefully it does.
Var
23
i've owned a dirtbike for a whole month. I spent more time reading and searching this forum than i have riding it.
Don't change your premix ratio.
Jet your carb. My bike was splooging like mad..through the rivets in the silencer. I repacked it and changed the jets. The bike doesn't smoke hardly at all and runs strong . Need to make some more adjustments for it to be perfect but it still runs a lot better with no oil or smoke.
do a search for jetting and premix ratio. There are a few hours of good reading to be done.
