It appears that a piece of foreign material is stuck in the upper couple threads where the oil drain bolt screws in on my '00 CR250.
The bolt is a 12mm diameter but I'm not sure of the threads per mm. I measure about 1.5 threads per mm but I don't want to use a tap in the hole until I make sure I have the correct one.
Do you know the correct bolt/tap pitch?
Any help is appreciated!
Thanks!
Thanks!
