Is your cracked or leaking? I've never heard of anyone changing this out except for the poor guys who have had lots of small metal pieces flying around in the case. :eek:
If you really need to replace it then just smack the old one out from the outside and pop in the new one from the inside...simple as that. I know cause i hit a rock and opened a section of the cover, i had a welder friend do a pretty good job on it and popped in a new window..good luck
Scottyx, I have a '96 kdx 200. I don't know if it really makes a difference or not, but it appears that the window pops out the other direction. I wasn't sure if there was some kind of adhesive used to keep it in place. I also broke the clutch cover. The crack and hole were to wide to repair, but luckily when I drained the oil there was plenty left and there were no metal shavings!!
