I ride a street model kdx 200, with a oil injection system (handy when filling up at gas stations) I came to the thought of the oil injector squirting the oil into the intake, and not atomizing the oil like premix would. My thought is this would result in a less efficient "burn" or "combustion" therefor, less power. Should I try pre mix? 50:1 (I think I can run my oil pump dry without any damage)
Even though my bike has a 28mm (too small :) carb, some sort of dual wall KH 220 pipe, and a lowered exhaust port for tuning of tourque, I still am un able to lift the front wheel off the ground without a fair amount of pulling/weight positioning in my part.
I realise the front end shouldn't just "pop" up when ever you twist the throttle becaue it's only a 200 right!, but I would like some more "snap" to say the least.
That's where the pre mix idea came to be, but perhaps I'm way in left field here, I dunno.
-thinking about a fmf tourque pipe
-high tension carbon fibre reeds
The bike is a Japanese production '87 KDX 200 SR ('93 equivalent North American Bike)
Any imput would make my riding experience that much better!
Thanks again!
Thanks again!
