oil mixture and drain plug questions
eddie1
39
ok so i just foundout i havn't been running the right fuel octain in my bike, 87 and on bikebandit it says to run 96+ on the scamatics dunno if this right or not, any oppinions?
What is the size of the BOLT for the tranny drain plug of a 1990 rm250(last one broke so i ahve no idea what size to use)
thanks
eddie1
39
looked but still no luck on the drain plug
n thanks f orthe advice ima go kick my freinds rearend now for not knowing his facts
eddie1
39
??? yup just looked for a hr now and still no luck on the darn screw or actual oil mixture.
cujet
826
2 stroke engines do quite well on 32 to 1, fuel to oil ratio. Make sure to use a quality 2 stroke oil. Not automotive oil.
Two stroke transmissions often use regular automotive motor oil. 10-30 is a good choice.
The drain plug is metric. Likely a 10 or 12mm thread with a 1.5 thread pitch. Sometimes, auto parts stores have replacement drain plugs that will fit. (sometimes in the "help" section) Make sure to use a gasket.
Good luck.
Chris
stumanarama
306
Good luck.
Chris
+1
